Originally posted by Irematic I've just recently started using the Pentax K-1 II, I'm running two Sony 64GB Tough SF-G memory cards in it.
The cards are totally clean, unaffected by the recall, have been formatted multiple times by the camera itself, and have never interacted with a Mac.
The camera will intermittently throw "Memory Card Error" after the cards have been removed from the camera, the photos imported into Lightroom, and the card "ejected" from the PC and returned to the camera.
It is not one particular card that does it, sometimes it's the first card, sometimes it's the second card.
Once I stopped removing the cards from the camera and started using a USB cable to import, the issue has gone away, but I don't like this as a solution as I don't really trust the rubber hinge covering the USB port to hold up to constant use over a few years.
Does anyone know what exactly causes this behavior?
It seems like a step backwards to switch over to the old SanDisk cards that are widely recommended here, and I doubt SanDisk cards are even any better or more reliable than modern Sony ones anyway.
This issue happens to me when the computer, or another camera, messes up the files in the card in subtle ways. For instance, upon changing "allocation size" in Windows, it threw these errors. Steps you can try are (for windows 10):
1. Boot up windows, change allocation size on both cards to default, reset all other settings to their defaults, and reformat.
2. Place the card in slot 2 and re-format again. Slot 2 is (surprisingly) able to format cards and make them perfectly usable and stable that Slot 1 refuses to read saying its corrupted. Maybe some bug in Pentax's UHS-I implementation, not sure.
3. Never delete images from the computer, or remove it without using "safely eject". If you are doing either of these, re-format the cards in slot 2 (preferrably) or slot 1 (if you are lazy) to reset them to defaults.
