Originally posted by Michael Piziak I know this isn't the best forum to post this, but I posted it at linuxquestions.org and also at a Gimp forum. Thought I'd post it here too and see if I get any bites.
Gimp EXIF data lost when exportingAfter I do some basic processing, then export (and the box is checked to keep the exif data), the exif data is lost in the resulting created file.
I'm using Gimp 2.10.24 a Pentax k-s2 camera
p.s. The exif data is retained if I overwrite. It's just when exporting that it is lost... I can't do a "save as" because the resulting file is not jpg (it's .xcf)
Regards,
Michael
Michael
__________________
Places I've posted this:
& reply/posted last post to this thread:
https://gitlab.gnome.org/GNOME/gimp/-/issues/7308 Gimp EXIF data lost when exporting
Hello Pentax Users here!
I am new at this forum and my interest to register was the problem when loosing Exif Data when using GIMP and almost does not matter what version.
So, i tested a lot with different Pentax Cameras, and i found a solution for the "EXIF DATA STIPE" when exporting. You all probably found out that when exporting to JPG format the EXIF DATA is included but if you are using TIF, and it doesn´t play a role if 8 Bit or 16 BIT, all EXIF DATA is lost after pressing export Button - and is lost in the exported file. But is still there, if you did not close the GIMP Editor and you can show Metadata as before.
Now, the point is, something must be different in the TIF Format we are using. Maybe not full compatible.
Courious that exported TIF Files have no preview image in Windows Explorer or XnView. Not even this wants to make a view when Using F11...
So I tested different options until i found out, we must have a look on GIMP´s export Window. The problem we have is based on the TIF Format. See the picture below. And my red arrow shows what you MUST disable to keep your Exif DATA into your new saved TIF File.
I am from Germany - excuse my simple language here. Using older Pentax cameras since 1980, still good with ME super, Super A, K100D super, K200D , K5 twice. And always was fed up when loosing Exif´s.
Now, after disabling BigFormat (TIF) i have a previe image in Windows Explorer, also in XnView, can see my Exif´s if i need or want and hope that you all can have this .
Try out the easy way in export window and i really hope that it works also with your GIMP version. I use 2.10.32 / 64 bit.
Regards,
Karl
