Originally posted by paulh I'm running Gimp 2.10.18 on Linux Mint. Under the "Edit/preferences" menu, under "import and export", make sure you check all the boxes relevant to retaining exif data.
I believe back when I was running 2.10.18, I was experiencing the problem with my old camera, the Pentax k-r, where EXIF data wasn't being retained with "Pentax" camera bodies (not Ricoh made ones), as is similar to this thread:
https://www.gimpusers.com/forums/gimp-user/20941-pentax-exif-data-stripped or this thread
https://gitlab.gnome.org/GNOME/gimp/-/issues/6316
Now that I have a Ricoh/Pentax camera body (the k-s2), probably I could go back to 2.10.18 and everything would work fine - might give that a try.... There is the chance though, that one of the Ubuntu updates, if I don't keep paying attention, will update over top of 2.10.18 with the current stable version in the repository
Also, I could install the lastest stable version of Gimp with flatpak, which is suppose to have the fix... The Ubuntu repository, however, should have the latest version of stable Gimp in it soon though....
Tahnks
---------- Post added 10-07-21 at 09:13 PM ----------
Originally posted by DougieD I'm using Gimp 2.10.2 installed with flatpak on Ubuntu. It works great. If I import an image from Rawtherapee and export that same image as a jpeg, the exif data is exported to the jpeg. However, if I copy a portion of the imported image and paste it as a new image, the exif data is not copied. Consequently, when I export the new image as a jpeg there will be no exif data. In that case, I use exiftool as kypfer mentioned above.
Yea, if the Ubuntu repository doesn't soon include the latest stable version, I'll take the flatpak route..
Thanks....
---------- Post added 10-07-21 at 09:22 PM ----------
I went back to 2.10.18 and everything works fine. But like I said, Ubuntu has a habit of "updating" software to its latest stable version in the repository....
I would caution anyone using a non Ricoh Pentax, that earlier versions like this can also strip the EXIF data.... Like I said previously, I experienced that with a Pentax k-r....
Of course, one could install any version with flatpak in Ubuntu, and flatpak installations aren't updated or effected by the Ubuntu repository updates....
Thanks everyone for your replies.... I have it under control now...
