Originally posted by photogem The screwdrive-motor makes quite noticable noices with any screwdrive-lens such as the DA55-300.
The DA55-300 is a longer heavier lens with more elements so the AF-motor inside the K5 needs to "drive" a lot.
That is very normal. Nothing to worry about.
The viewfinder cannot go On-and-Off! The viewfinder is an optical instrument like glasses.
The other way to "find a view" is LiveView, i.e. you see the desired object on the LCD Screen.
LV is often much slower.
If the mirror flips up and down, you have to check this carefully and google "Pentax mirror flop", then you find samples on youtube and you can listen to that particular sound and compare.
What you actually are using is AUTO-mode, there is no green mode but the green-button method for manual lenses which is nothing for you.
With Auto-mode you won't be able to shoot birds really, too many ??? for the K5.
AUTO-Mode is almost useless, the K5 is for those who can work with Av, Tv or Tav etc.
If you don't master Av at least, then the K5 is not for you really except you are willing to learn how to master "real modes".
For beginners a K30/50 or K-S1/K-S2 or K70 is better because they at least allow SCN = Scene modes.
A start would be P-Mode which is Auto when switched on by you can "override" Auto by turning the front and back thumbwheels and thus "align" to the given light situation etc.
when i turn my K-5 on it literally says "green mode" on the back screen, but yeah, auto mode is not very good, i am learning P mode currently, when i said the view finder "goes off and on" i was referring to it rapidly going dark and then light over and over if i held the button down, i know it's a D-slr, i just dunno what that is called, i assume the mirror is doing something, because light stops going through view finder and it goes black for a fraction of a second over and over while the camera makes a chek-it chek-it kind of sound, i gotta make a video and figure out how to attach it on here, i'm new to pentax, new to dslr's and photography. i stopped using "live view" because with this DA 55-300 the time it takes to focus this lens is terrible, but it's only slow in live view mode, i dunno why that is. thank you for the input and feed back, i'm learning as i go, kind of...slowly
---------- Post added 10-10-21 at 02:43 AM ----------
also it seems to only happen in very bright sunlight, i have turned off a few settings, so tomorrow i'll go out and see what happens, i looked up mirrior flop and it doesnt really sound like that and it also makes the noise when you use any button or wheel, i'll try and make a tiny video clip of it happening tomorrow. i turned off the dust cleaning on startup and also turned off the setting that doesnt allow the camera shutter to open if it's not in focus, since i made a "user" profile, i can just go in and turn off everything thats on in that profile and maybe one of those things will work. i thought maybe it was the lens because i bought it used and the person shipped it across country in a soft envelope in a bubble wrap bag but the bubble wrap had like no bubbles left in it, anyways i'll keep looking for videos on it, sadly there is only a few (most of them are from 2011 on youtube) i guess pentax isnt that popular anymore
the k-5 is my second dslr, i started with a Olympus E-420 from 2,008
my budget is limited so there will not be anymore cameras for some time, so this k-5 will work or it wont and i'll just toss it and do something else. i'm not attempting to go pro or anything, i just want something to do that gets me out of the house and moving that doesnt involve meeting people, or even seeing people, which photography can do perfectly since half the people on the street run away or cuss you out if you even look like your pointing the camera at them, since i hate most people i stick to animals and bugs and things. (i talk about as well as i type, thats why this is my first forum ive ever tried to use,.
