I'm building up a camera based on the Raspberry Pi system and happened to find out the UV/IR cut filter is in the mount rather than bonded to the sensor. This would make having a full spectrum camera trivial as one could just omit the filter during assembly.
The lens I intend to use accepts 30.5 mm filters but outside of a couple offerings on AliExpress I don't find any UV/IR cut filters in this size. I can use a 37mm filter with a step up ring but would like to keep the smaller form. Has anyone come across a cut filter in the 30.5mm size?
