10-13-2021, 04:54 PM   #1
Change Date and Time on Pentax K-5
I just bought a used Pentax K-5. I am unable to change the date and time. The user manual only tells you how to set it the first time. Can anyone help? I did a google search to no avail. Thank you.
---------- Post added 10-13-21 at 04:58 PM ----------
Okay, ask a question, figure it out. I went to Menu and then just kept clicking to the right and it finally got to spot that allowed me to set it. No rhyme or reason as to how I got there, just click, click, click until you see what you want.
10-13-2021, 08:34 PM   #2
Welcome to the Forum.
Good you found it; but there is logic to the menu. Across the menu to the "wrench" page 1, down to date adjustment, right to enter date adjustment,Then you can change the date format/24 or 12 hour time, down to date -right to change, date, left each time to get back to the date adjustment page, last item is time, left to exit time, then down to settings complete and click ok, then menu to exit. The green "arrows" show you there is more to do or to exit/change the value.
You change the date the same way as you set it the first time.
10-14-2021, 03:18 AM   #3
QuoteOriginally posted by lindalou Quote
In the printed manual index, under Date Adjustment, it'll reference you to p67 … or in the pdf version just do a search for date
One big advantage of the pdf version is being able to search for keywords, rather than hoping the word/phrase you're using has been included in the index (Time isn't in the index!)
10-14-2021, 03:21 AM   #4
RobA_Oz's Avatar
Good you got there by yourself, but don’t be shy in asking for help in future. You’ll find lots of helpful people with good knowledge, here.
Welcome to Pentax Forums.
camera, change, change date, click, date, date & time, date adjust, date and time, k-5, k-5 & pentax, pentax, pentax help, photography, time, time on pentax, troubleshooting
Photo Taken Date vs Making Date RoundWharf General Photography 16 02-12-2019 02:53 AM
Lost date and time settings with battery change jacamar Pentax K-r 17 11-05-2017 09:45 AM
Original Q: Date and Time resets every time I charge the battery? Senduy Pentax Q 3 12-29-2014 12:47 AM
help! pentax K-M requires adjust date time all time carl zeiss Pentax DSLR Discussion 9 10-05-2012 07:27 PM
Date and time reset at battery change TJWest Pentax K-30 & K-50 2 08-06-2012 02:29 AM
All times are GMT -7. The time now is 09:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
