Originally posted by tampa Thanks Bob -- that is an interesting point. I looked on the back of the camera, and did not see anything obvious -- I did attach a photo. Maybe you (and anyone else interested) could take a look? As I said to a few other folks who are trying to help, I cannot think of anything that would produce a line that straight except for the curtain. But I would expect the curtain to be dark all the way up to the line itself. I thought possibly the film was being stretched, but it is weird that it always happens in the same spot. Any ideas after looking at the new image attached?
If there is a "pinch point" which might be applying pressure to the emulsion as it's dragged over it, it would be on one of the rails (rollers) at each end of the film area or near by, and that should be
directly under the hazy area on the pressure plate when the film back is closed. If those are rollers, spin them with your finger to make sure they are free and roll as they should without binding.
Are these areas on the negative showing between images (in the borders between frames)? That would indicate that the film damage is occurring while the film is being moved between shots. If it shows only on the exposed portions, then it could be something on the FP shutter rubbing when a shot is taken
or It could be damage to one of the shutter blades which is causing a slightly different exposure at that point as the shutter slit races across the film. You might be able to see this if you open the back and slowly cock the shutter while looking at the blades as they are reset (though the edge of the first blade will be covered by the second and you might not be able to see any damage to its edge). You could also try looking through the camera with the back opened and without a lens while it's held up to a very flat, lighted background. Then you might see the actual lightening when the shutter is tripped (use a fairly high speed like 1/250 sec.) if there's shutter damage. If it's shutter damage, that would be a job for a camera repair shop.
