Originally posted by jawats Bob,
My apologies - I wasn't clear. By "cooler air," I meant that I am going from inside (about 72) to outside, cooler (fall) air, at about 35-50 degrees F, depending on evening.
At any rate, condensation would not seem to be an issue going from warm inside to cool outside air.
However, I will also bag (Ziplock Feezer bag?) my lens with some desiccant packs (silca gel) I have, to try to wick any moisture.
It goes against logic, but if the air outside has enough moisture, equipment will act like a magnet, condensing that moisture onto their surfaces once the equipment cools down to the outside temperature. It's not a problem while the equipment is still warm from being inside, but after it cools. That's why a dew heater works, it keeps the equipment above the "dew point" of the surrounding air. If the air is dry, this won't happen, so really cold outside environments (significantly below freezing) where all the moisture has frozen out, won't present much of a problem. In any case, a dew heater is a good idea when you have this problem, and keeps your equipment from fogging unless the environment is really saturated with moisture (think foggy day).
The other thing that's bad is that as your lens or equipment cools, any air spaces in it will cool and the air therein will shrink drawing the outside air into the equipment. That might explain why you can get fog inside a lens over time unless the lens is sealed completely air tight (not usually the case for technical reasons). Bagging equipment can keep this from happening, but the desiccant will draw out this moisture given time.
