11-07-2021, 09:58 AM   #1
jpzk's Avatar
Using the K5 here: which firmware version is needed for the D FA 150-450 lens ?
I have been "testing" my daughter's D FA 150-450 on my K3 ... all is well so far.
I am planning to test it today with my K5 ... I have firmware version 1.16 installed on the K5.
Will that firmware version work?
Thanks !!
11-07-2021, 10:20 AM - 1 Like   #2
Not a Number's Avatar
Why not use the compatibility checker?
Pentax K-5 and HD Pentax-D FA 150-450mm F4.5-5.6 ED DC AW - Compatibility | PentaxForums.com
11-07-2021, 10:47 AM   #3
Seeker of Knowledge
aslyfox's Avatar
there are some great resources here at the forums
Major features subsequently added through firmware updates:
Version 1.16: Support for the HD PENTAX-DA AF 1.4x Rear Converter
Version 1.15: AF assist light function made compatible with the new flashes, AF360FGZ II and AF540FGZ II
Version 1.10: Added support for O-GPS1 Astrotracer
Version 1.02: Added support for SDXC memory cards
Read more at: Pentax K-5 - Pentax K-mount DSLRs - Pentax Camera Reviews and Specifications
Year Introduced 2010
In Production No (Discontinued 2012)
compatibility All Pentax DSLRs from 2006 onwards
(no AF with prior models)
All A-series film SLRs and newer
(prior manual models always shoot at minimum aperture)
Origin Assembled in Vietnam
Note that firmware updates are required for the Pentax K-S1, K-S2, and K-3 for full compatibility and optimal focusing with this lens. Older cameras will not fully support the dedicated AF buttons found on the lens barrel.
Read more at: HD Pentax-D FA 150-450mm F4.5-5.6 Review - Specifications | PentaxForums.com Reviews
11-07-2021, 10:54 AM   #4
jpzk's Avatar
Thanks !!
So it says "Fully Compatible" which is great.
I will go and "test" that lens on my "old" K5 now.
---------- Post added 11-07-21 at 12:57 PM ----------
Thanks !!
As I said earlier, I will do the testing today.
Just wondering if the small AF buttons around the lens will also work ? We shall see.
---------- Post added 11-07-21 at 12:58 PM ----------
And while I'm at it, will the D GB5 battery grip on my K3 work on my old K5 ?
Thanks!
11-07-2021, 11:49 AM   #5
Madaboutpix's Avatar
QuoteOriginally posted by jpzk Quote
And while I'm at it, will the D GB5 battery grip on my K3 work on my old K5?
AFAIK, the battery grips are all camera-specific, although they can be used on the Mk. II iterations of the same model. For the K-3 III, Ricoh designed a new dedicated battery grip.
11-07-2021, 11:57 AM   #6
RGlasel's Avatar
I hate to be the bearer of bad news, but
11-07-2021, 12:00 PM   #7
Seeker of Knowledge
aslyfox's Avatar
. . . And while I'm at it, will the D GB5 battery grip on my K3 work on my old K5 ?
Thanks!
no
Description:
D-BG4 battery grip for use with the K-7 DSLR and the K-5 DSLRs.
Pentax Battery Grip D-BG4 for K-5 and K-7 reviews - Pentax Camera Accessory Review Database
Description:
The D-BG5 is a grip for use with the Pentax K-3 and K-3 II DSLRs. The grip is weather-sealed like the matching camera body.
Pentax Battery Grip D-BG5 for K-3 / K-3 II reviews - Pentax Camera Accessory Review Database
11-07-2021, 04:54 PM   #8
jpzk's Avatar
Thanks to all !
The info is much appreciated.
The lens works fine on both cameras but .... as mentioned by RGlasel ....those small AF button ln the lens do not work with the K5 but work great on the K3.
So much for trying to make "new" stuff work with "old" stuff!
As for the battery grips ... too bad the K3 grip will not work on the "old" k5!
Cheers!
11-07-2021, 07:23 PM   #9
jpzk's Avatar
Thanks !!
150-450mm, camera, dslrs, f4.5-5.6, fa, firmware, hd, k-5, k5, pentax, pentax help, pentax-d, photography, reviews, specifications, thanks, troubleshooting, version
To 150-450 or not to 150-450? bertwert Pentax SLR Lens Discussion 50 01-05-2022 11:47 AM
K-3 III Firmware 1.02 and D FA 150-450 issues Kobie Pentax K-3 III 8 06-25-2021 11:56 PM
Owners of Pentax 55-300 and 150-450 - Are you still glad you bought the 150-450? Joyce Keay Pentax K-70 16 02-17-2018 05:55 PM
Simple lens shootout Pentax HD DFA 150-450 vs Canon 100-400 II vs Sigma 150-600 C beholder3 Pentax SLR Lens Discussion 46 07-25-2016 12:33 AM
K5 firmware upgrade which version? selar Pentax K-5 & K-5 II 15 11-23-2011 08:58 AM
All times are GMT -7. The time now is 09:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
