Thanks to all for your replies and suggestions. I think you've helped point me in the right direction.
Originally posted by Parallax If the area is a relatively small portion of the circumference, as it appears to be in the photo, just file or cut that down to the base level.
Yes, the damage is limited to what's in the photo. And for that basket case lens, I'd be willing to try your suggestion as an experiment. But I have another lens with the same problem with which I'd like to be more gentle.
Originally posted by 35mmfilmfan Would a pair of dividers from a school geometry set be fine enough and sturdy enough to do the trick ?
If I had a pair, I'd give it a try. But I think a dedicated tool would probably be more effective.
@crazy4oldcars & @MikeMcE
: I'm going to buy a file as you suggested.
Also, this tool looks to be a possibility
: McMaster-Carr
It appears they don't have a metric .75 pitch die, but I believe the 24 TPI die would be equivalent.
