Firstly a big thank you to those who advised me on the e-dial issue - erratic behaviour due to dirty contacts - and to the advice about updating the firmware, which, after a fair bit of ineptitude on my part I now have sorted!
However, there now appears a strange thing or two which again I am at a loss to explain or sort out. I suspect they are all linked in some way which I am missing.
On every mode other than M and B the LCD display insists on showing the exposure compensation reading (the -2.0 to +2.0 thing). And when this shows the remaining exposure number doesn't of course. Pressing the +- button does nothing. The e-dial does correctly change this reading but the only way it will disappear is on the M and B modes. Also, the zooming feature on playback using the e-dial now doesn't work at all. I should add these issues appeared before the update and remain afterwards.
Again the camera itself works in every other respect. However, the modes other than AUTO are pretty much useless unless I can get rid of the exposure compensation issue.
Hope that's clear. Maybe the electronics have terminal malfunction now?!
