Originally posted by mikesbike Yep. My K-5 series cameras do likewise. And so does my K20D. In fact the rear LCD screen stays blank unless I press a button to bring up a display on it. The top LCD displays exposure settings, etc. but even it will soon turn off if no activity, and will come right back on with a shutter button 1/2 press.
Yes, but not after 2 seconds!
It stays on for about 15 seconds!
He cannot bring it back with the 1/2 press on the shutter-button!
If one reads the given information one knows that first his back LCD was malfunctioning like this:
Now, after he took the time to reply during the flood-problems (@MarkJ: Good luck with that, hope things are not too bad)
we know that now it seems to work alright but switches off 2 sec. later.
This is NOT NORMAL!
@MarkJ:
This is the back-part of a K10D but if I recall it the only difference is the size of the LCD itself (2" vs. 2,5" on your K20D),
You can even switch the K20D ON and OFF with that part connected to the mainboard but open, as long as the top part sits firm in the main chassis.
I marked the 2 parts which could couse your problem. Another option: Check battery power! Could be that your main battery is weak?
