Originally posted by AfterPentax Mark II Usually you press the menu button to get to the menu's. The OP describes what happens if he turns it on. And that is normal behaviour.
No, he describes that the LCD does go on and 2 sec. later goes off. He has no access to the menu.
Best to read the whole story:
K20D screen failure - PentaxForums.com
and then again his first post in this thread.
Understand the meaning of:
"when i found out how expensive the cheapest repair possibility would be for the repair of my old camera’s malfunctioning rear screen."
Unless he has repaired it (I asked how far he got with that or if anything was done") there is
ZERO possibility to get into the menu and follow this advice:
"Ensure that the
"Using Aperture Ring" custom function is set to
"2 (allowed)"
