Originally posted by DamienW I hate the Adaptall mount...so fiddly. Not a great mount to add and remove. I have the 2x converter, which must be placed between the lens and the adaptall mount - real hassle to get on and off. Maybe it needs some sort of lube.
If you're using a Tamron original mount, they certainly can benefit from a clean and re-lube' … they do get stiff over the years.
For the 500mm mirror, I use one of the after-market Adaptall-PK adaptors. No aperture linkage to get stiff, so no problem on the 500mm
The original concept, of course, was to fit a separate mount to every Tamron lens … only needing to remove the mount if you changed camera system
Obviously the 2x was always going to be a problem, but at least if you bought one you didn't need to buy another if you changed system
Some of my Tamrons are on their fourth mount! M42 to Fuji-screw to Fuji-bayonet to PKA
