If the OP is unfamiliar with what the lens looks like "normally", is there any chance there's an extension tube fitted?
It'd have to be a Tamron Adaptall tube, obviously, as supplied for the 90mm macro, but weird things happen
Alternatively, (grasping at another passing straw), has the internal interchangeable filter, at the rear of the lens, been replaced by a close-up lens or similar?
I'm unfamiliar with the #55BB specifically, but on my #55B the rear "element" (the interchangeable filter) is marked 'TAMRON 30.5 NORMAL JAPAN' on it's periphery, only readable with the mount removed.
