While experimenting with a 42mm screw in lens I managed to get some debris on the focusing screen of my KP. The worst bit looks like a large seagull flying across the top of the frame and there are various other smaller bits. I've tried blowing 'em with my hurricane blower, but to no avail.
I started to look into removing the screen to clean it, but cleaning these things looks problematic in itself? So I then thought about replacing it, but screens I can see advertised here in the UK, such as the ME-60, MF-60, MI-60 or ML-60 [all available with a fitting kit from Bristol Cameras], although they appear physically to fit the KP, have designs that are totally different from the currently fitted screen.
I'd welcome advice from those with experience of this issue.
Thanks.
