11-24-2021, 10:04 PM   #1
Error symbol (E) on LCD
I recently got a Pentax iqzoom 160. This is my first film camera so I’m not entirely sure how this error happens. I loaded the camera with film and I’ve taken 8 photos so it says 8 on the LCD. I put it in my pocket earlier today and when I took it out, it was flashing “E”. I ended up having to take the film roll out unfortunately but does anybody know how this happened and how to avoid it?
11-24-2021, 11:07 PM   #2
Not a Number's Avatar
The user manual can be found here:
breathtaking | Pentax IQZoom 160 | IQZoom 160 Manual (Page 2)
It says "If ( E ) blinks in the LCD panel, it means the film is not properly loaded. Reload the film."
Perhaps the battery is low or the winding mechanism is faulty.
11-25-2021, 07:35 AM   #3
How do you think that happened though? I was on the 9th exposure already. Did I press a button I didn’t know about? Also what’s the proper way to rewind or reload the film if I’ve already used up some of it.
11-25-2021, 09:13 AM   #4
35mmfilmfan's Avatar
I believe page 29 of the aforementioned manual will give you the information you require.
11-25-2021, 09:21 AM   #5
I cannot suggest why or how the fault happened. However, you can try to use the film again by loading the film, covering the lens so that light will not enter the camera, and then advance the film by pressing the shutter button 9-10 times. That will preserve your first images and avoid any possibility of double exposure on the 8th frame. If the film tongue has been retracted inside the film canister, you'll need a small extractor tool to retrieve it.
11-25-2021, 05:22 PM   #6
Hello, I have an Espio 115G and I have seen the same "E" flashing in my screen to. In my case it was related to the lens unit. after zooming in and out a couple of times it would go away. my best guess is cogs freezing from long time not being used.
camera, error, error symbol, film, lcd, pentax help, photography, troubleshooting
Suggestion [QoL feature] Mark a topic/thread as read by double-clicking the symbol next to it ehrwien Site Suggestions and Help 2 09-20-2021 07:05 AM
Fixing error message "lens error 0x0111 Paul Lohr Visitors' Center 4 09-17-2020 11:13 AM
Suggestion Like symbol colour bertwert Site Suggestions and Help 3 12-19-2019 10:06 PM
K200D battery symbol in LCD flashes, even with good batteries jaytaz Pentax DSLR Discussion 10 09-01-2010 03:31 AM
All times are GMT -7. The time now is 08:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
