Originally posted by Thrashercharged
grainy are photos taken at 3200?
As UncleV says, but basically the same idea in disturbing high quality results, and in this case even accompanied by disintegration of image integrity if going beyond a certain point. With noise and ISO, depends also on how much the user deems acceptable. It also tends to show up first in shadowy areas, so how visible it will be at its first appearance will also depend on the nature of the scene. With the K-3, noise will become quite visible at ISO 3200, especially in shadowy areas, but for some people might be tolerable for some uses. I'd say a KP camera, a compact design yet having a likewise durable magnesium alloy metal build, has about 1-1/2 stops more ISO available for good results. The FF K-1 II can do at least another 1-1/2 stops. I have both, and these results are within my general use standards, even though I mostly shoot JPEGs right out of the camera. With some scenes I might be a bit more picky. There is also some very good further noise reduction processing available from certain available software. The new K-3 III appears to be even closer to the K-1 II in higher ISO performance.
Seems to me I recall sometimes using a commonly-available Fuji ASA 800 color print film that was outstanding for pretty good results at such a high sensitivity.
---------- Post added 11-30-21 at 06:49 PM ----------
I assume this is to take photos in near dark conditions without a flash
Yes, I do quite often shoot night scenes, and sometimes even having some subject movement. Also for shooting fast action subjects in less than bright conditions in order to get high enough shutter speed to achieve clarity.
ISO 1000 or even 1600 is no problem for a Pentax K-3 camera. You can expect clean results. If you're going to be very picky, keep to ISO 800 or less. Just take some shots and determine for yourself.
