Originally posted by shyrsio But how do you get the battery to stay put? the D-LI109 has some sort of hooks to keep the battery in place, the D-BC90 does not provide those.
Well, this is where the magic happens, if you push the Dli109 in the DBC90 charger with just a little punch it fits perfectly.
I finished charging 2 Dli109s they seem in perfectly good shape. And the green dot appears on charge then stops when charge is done.
---------- Post added 12-08-21 at 07:13 PM ----------
Originally posted by bertwert Well, they both output 8.4V at 400mA so no problems there. D-LI109 seems to squeeze onto the D-BC90 well enough as well - though vice versa is not possible.
The only difference that may matter is the D-BC109 has a fourth "D" contact that the D-BC90 does not - I'm not sure exactly what it does, but as I understand it third party chargers don't have it either, so I guess it's probably not going to go up in flames.
Interesting observation, I never would have thought to try this and could be useful in a pinch!
I'll post an update after 3 complete cycles with Dli109s on the same Dbc90 charger , just to see if the combo stands in time.
