The rest of the series here:
Clackers' Beginners Tips (Collected) - PentaxForums.com
'Grandad, how do stars die?', Olivia asked me, full of wonder.
'Drugs, normally', I replied.
It got me thinking, we all learn, and there are beginners in this group too ... why not some tips on basics, like upgrading firmware on our cameras?
It's a specific process, the actual instructions and necessary caveats for each model are on the Ricoh website:
Software Downloads : Support & Service | RICOH IMAGING
but here are some tips beforehand:
1. I always upgrade firmware when it becomes available. I'm in IT, and can tell you that with changelogs, there is a list the company engineers, and a list that gets revealed to the customers, and they're very different. The fixes can be for situations or hardware combinations that the testers and brand ambassadors never discovered in their limited time with the product, or embarrassing oversights. You protect them by simply saying something like 'General performance stability'.
2. Don't assume anything, take out your battery and charge it up beforehand. We've all seen how when a device is turned on, the battery at first registers full strength until its true state is revealed. The power cutting out during a firmware upgrade can 'brick' your camera, requiring a fix at the factory or authorized repairer.
3. On your computer, download the .zip file. It's not self-extracting even though the website says it is, you need a program of some kind (Windows itself will do this) that will let you double click on it, then take out the .bin file inside. That's what goes on the SD card you'll use for the upgrade.
4. You have to put the .bin file directly into the SD card, not into any folder that's on the SD card. If you format the card beforehand in your computer, that's ideal. If you format in your camera, that happens to make a 'DCIM' folder. Resist the temptation to put the file there, just as Hollywood stars should resist the plate of powder being offered them.
5. Now put the card into the camera ... if there are two slots in yours (you rich b*#$%^!), it needs to be Slot 1.
6. Hold the menu button down while you switch the camera on to begin the process.
Good older video on this here:
Pentax Firmware Update Guide - Tutorial Videos | PentaxForums.com
