Possibly there is dirt under the mirror (don't lift it up mechanically!).
First try with a blower but make sure you don't use anything that can leave residue (such as an earstick)
The way I cleaned dozens and more of Pentax bodies was this way:
https://www.pentaxforums.com/forums/62-do-yourself/433175-modify-vacuum-clea...static-esd.htm
(now I have a prof. ESD vacuum-cleaner)
Carefully study the thread and find out if your house is save but I think in Sweden you have the same standards as in Switzerland, Germany or UK.
Don't "give a damn then" about the "strong hesitations" but just "do it".
If this does not help, you must sadly have "hurt" something else.
Then only a good patient search can help
Maybe, but only a strong maybe... it is the lens.
