Hey there!
I'm experiencing some problems with my 645 NII and 45-85mm f/4.5 lens and thought someone on this forum might know of a solution.
In certain cases the pictures are severely underexposed, to the point that they are not salvageable. The camera has a feature that lets you print the shutter speed and aperture on every picture, and I've been using this to diagnose it. Based on this, the meter in the camera seems to work as the shutter speed and aperture are spot on. However some pictures end up underexposed. A striking example of this is attached to this message: I took two photos successively in the same lighting conditions, and the meter measured 13.5 EV in both cases, but one of the pictures is underexposed beyond salvation while the other is perfect. I suspect it could be a problem with the shutter itself, or the aperture of the lens. I want to point out that the problem seems to happen in P-mode, and not in aperture priority.
Is anyone familiar with this and could point me in the right direction to fix the camera?
Thanks!
-Guillaume
