Hurray! My new (used) macro lense arrived today. The seller told me the autofocus does not work and I got it for a really good price.
While the non-functioning autofocus does not bother me at all, there actually seems to be a second problem that I was not aware of when I bought it. The aperture simply won't open when the lens is mounted to my K-50. It is always dark in automatic mode, and when I preset the aperture using the ring, it stays at that aperture even when focusing. As a result the lense is completely unusable for me as I typically shoot between f11-f16.
Is this a known (fixable) problem or should I kindly ask my money back? I actually asked if there are more problems that I should know about and the answer was "no". I am feeling quite puzzled right now. Do I have to bend out the aperture lever maybe as it appears to be quite far towards the center? I can open the blades using my fingers after all.
I am also curious if the autofocus can be repaired DIY, but that one is not too important.
Thanks for any help or advice!
Edit: I tried the lens on my K100 Super and it behaves a bit different there. If I turn the aperture ring starting from wide open the blades will be completely open at F2.8 and gradually close until F8 when nothing is happening anymore. In "A" setting, the blades will only open up a tiny bit. The same is true when I remount the lense while having it in "A" position. It must be because of some sort of contact issue between lense and camera. But how fo fix it?
Edit: The blades are actually closing down better if I put an extension tube between camera and lens, but they still stop closing down any further at higher f-stops.
[PROBLEM SOLVED]
I opened up the back plate, bent the lever and after that both the aperture blades and the auto focus work perfectly fine. I am not sure what caused the AF to not work, but I am happy it does now. =)
It was neither caused by the limiter nor the lens or camera being in manual mode.
