While driving to a town to shoot a pro cycling event one year (the Sky team complete with Chris Froome were there), I picked up a hitch-hiker. Seemed like a nice guy. After a few miles, he asked me if I wasn't afraid that he might be a serial killer. I told him the odds of two serial killers being in the same car were extremely unlikely.
After a little diversion, at the venue I went to get my gear out of the back of my car. My K-1 was there beside the usual duct tape, sheet plastic, cable ties and shovel (which now had fresh dirt on it). But I accidentally had left its electronic shutter on from the last time I used it.
The Pentax Q, K-1, KP and K3-III have that available, with increasing levels of sophistication.
A quick primer on shutters.
The old fashioned style 'leaf' shutter built into a lens - my Ricoh GR II has one, and some 645 lenses do too - is like if you form a fist, and open it, with the back of your hand pointing away from you, and close it again. Note that you see your open palm longer than the insides of your fingers. This means the center of the picture gets more exposure than the edges, and this is a practical limit on how fast the shutter can be - perhaps 1/2000s.
The modern focal plane shutter might go to 1/8000s, and it's like two blades (curtains) with a gap between them dropping down over the frame.
I have a K-30, and 1/180s is the smallest amount of time the curtains are apart across the whole frame, so its popup flash is disabled when less than that so we don't get a progressively bigger black band in the picture.
The curtains are of course mechanical, and in combination with certain lighter lenses at certain low shutter speeds (perhaps less than 1/200s) the snap of the mechanism can cause detectable blur when pixel peeping.
The K-1 (which has a bigass, heavy full frame shutter) offered as a firmware upgrade a 'half' electronic shutter for that situation. Only the second curtain drops, meaning most of the shaking never gets recorded by the pixels.
The KP can have purely electronic, which means in Live View it can be silent when it shoots, and the shutter has no wear and tear.
What are the problems? Well, almost no camera has the electronics to switch on, switch off and read all its pixels simultaneously. The reading occurs in rows from top to bottom, so each pixel might be on and off for 1/8000s, but the pixels at the bottom record maybe 1/15s later than the ones at the beginning. If an object is moving, that can be noticed as distortion - see my pic below from that morning. Or if there's lighting that's not constant like fluorescent lamps or flash, there can be weird bands.
Flash is certainly disabled in the Pentax implementation of this technology, but the K-3 III apparently has solved the problem of the sensor moving during that time, and I hear that shake reduction can now be used. Katie got her electronic shutter enabled after about firmware 1.10, IIRC.
From time to time, people have argued that paying a lot extra in a stills camera for a global electronic shutter as used in all high end video bodies will end these limitations, but the truth is that to read every pixel at the same time requires extra electronics around each pixel that increase noise and deliver grainier pictures. Nevertheless, the upcoming Canon EOS R1 may have one for maybe USD $6500 or more.
On the way back to the city from the event, I picked up another hitch hiker. I asked him, "So, where did you think you were going?"
The rest of the series here:
Clackers' Beginners Tips (Collected) - PentaxForums.com
