Originally posted by chrodo7 To add to my confusion, there is a light leak AFTER the the last frame of the roll (see the photo of the end of the negative I just added to the post). Wouldn’t this mean the light leak has to be coming from the canister side of the back?
Not confusing at all. The film image frame is in the centre of the back of the camera. The light leak is to the left side of it, so somewhere on the canister side, so that can easily be the door seal.
An easy way to solve this: Put black electrical tape on the outside edges of the film back after loading a fresh roll. Take a few shots. Peel off one strip of tape (eg left side first). Then shoot a few. Then put it back, and peel off right side. Shoot a few more. Lather, rinse, repeat until you`ve gotten all the edges. Then yoù`d know for sure.
Plus, if one seal is bad, probably all of them are going to be bad, so it`s worth doing the lot of them.
---------- Post added 01-12-22 at 09:00 AM ----------
Originally posted by sfkazimierczak Hi. I know it might be a long shot as well, but did the camera went through some kind of security scanner? I had a similar problem on my ME Super. I have a scanner at work and didn't think it was that powerful, but as it turns out it is. I was confused what caused light leaks in my camera and then I realized they appear only on rolls I had with me in my office. Now I always remove my camera from my bag before security check and everything is ok. Well, was because my MES stopped working altogether but that's a different thing. Other than that it does look like a bad hinge seal.
Any kind of x-ray source would damage the entire roll, not a thin strip at the left edge of a frame.
