Originally posted by Timus I am having trouble too often with my new K3iii LCD screen being blacked out. I've reset the camera, removed all power for a minute or so with no change. Later on (when I don't need too shoot) I power up and all is good. Anyone having the same issue and found a remedy? Thank you all for the assistance.
Hello I had the same issue. I bought the camera in May 2021and 3 months later started this problem, when used Limited 15 mm lens, I meanchanging lenses. I have thought the issue was caused by the lens, so sold itout and bought new 11-18. Unfortunately, issue went on. I switched camera onwas able to take pictures, but back screen did not work, had to delete all thesettings, switched on/off and then started to work for some time again.
In the end of the last year, however, there appeared moredifferent issue. When powering the camera on, the burst for continued shootstarted, the same when swapping from OVF to LV. For some time I was able totake single picture in LV not OVF. By the end of that day no pictures couldhave been taken. Deleting settings, powering on/off had no effect.
I have sent the camera to service at the beginning ofJanuary and now after three months, new camera is being delivered. Technicianswere not able to fix it neither in Prague nor in Berlin.
Will see if the issue continues.
Meanwhile I have bought Fuji x-h2 and I am fully satisfied,will see how to deal with Pentax K3-iii soon.
