Yes, the aperture setting was set to f11, ISO 1000.
That VF and LV differ is what baffles me, apart from the fact that I usually shoot with the VF and that doesn't really work.
(I should perhaps add that in M-setting I get no info about metering, under- or over-exposure, as I would expect. Have used film cameras for the last months mostly so my memory is a bit foggy, but I believe I used to get that info.)
---------- Post added 02-08-2022 at 02:51 PM ----------
Originally posted by Fogel70 It sounds like a slow aperture on the lens, so it does not fully stop down before the metering is done right before exposure in VF mode.
But I believe the aperture is always stopped down in LV mode, so then it is not affected by a slow aperture.
Not sure what you mean by slow aperture but:
- it happens with any M-lens or K-lens that I mount so it is independent of the lens
- there still is an info difference: LV displays shutter speed in Av-mode, VF displays AUTO in Av-mode.
---------- Post added 02-08-2022 at 02:57 PM ----------
I just put an A-lens on the A-position, and that works as it should: no difference between LV and VF views or exposures.
In M-mode, it also displays over- or underexposure.
Perhaps I'm misunderstanding the M- and K-lens functionality, but the difference between LV and VF remains strange.
