Originally posted by Adam All recent Pentax DSLRs require P-TTL compatible flashes (not film era TTL) if you want full auto exposure. Otherwise they will always fire at the preset power and you will need to set the shutter speed and aperture manually.
Model numbers would be helpful if you'd like more tips.
Thanks for your interest. No, this isn't an old model, it's a 24-AF1P in a brand-spanking-new box. In the instruction manual, or what passes for an instruction manual, it lists quite a few modes, including "TTL flash control" and "PTTL" flash control, plus "P-TTL fill-in flash control" and a bunch of others. The connecters on the base match those on the camera--four of them. As the Germans say, "Es stimmt, aber es stimmt nicht" (It agrees, but it doesn't agree). I went all through the camera's menus, and I couldn't see anything that would solve my problem. I'm thinking this is just some "senior moment" thing.
---------- Post added 02-11-22 at 07:59 PM ----------
Originally posted by stevebrot Let's ignore the Metz for a bit...
What Pentax brand flash did you attempt this with?
Which Pentax 50/1.4 are you using?
Hi. The Pentax flash is from film days, so I'm sure I'm out of luck. I think it cost me $10. Thanks.
---------- Post added 02-11-22 at 08:02 PM ----------
Originally posted by UncleVanya Thanks for the links, UncleVanya. I'll go through all of them.
