Originally posted by photogem He's using an *istD but accidently the impossible happened: He downloaded the latest *ist-DL firmware not realizing it and... it worked, the *istD did the update.
He also uses the CF to SD-Card adapter.
Am I using a CF to SD-Card adapter? From what I can tell my camera only takes SD cards, and it has a Push to Eject SD card icon under the flip latch.
But yeah, *istDL firmware flash works for the *istD, atleast from firmware 1.0 that I had, and seemingly no problems, have had a couple freezes/crashes but bounced back after popping the batteries out, as it wouldnt fully turn off in those cases.
---------- Post added 03-06-22 at 01:15 AM ----------
Originally posted by steephill Is there some basic confusion about which camera we are talking about here? The *istD uses CF cards so you can't flash the firmware with an SD card unless you are using an SD to CF converter. The later models in the *istD series (DS, DS2, DL and DL2) all use SD cards.
Ohhh didnt see this before. I probably have a DS or DS2, though it just says *istD on the body's front so idk, makes sense on the CF card and SD card confusion aha
