Originally posted by drab It does only show as Ver 1.03 sadly, but the debug mode is good to know about. Not a Number mentioned hacking the header, would that be from the debug mode or something different? Gonna do more research now that I know the stuff to look for properly, but also probably will only do this if 1.03 works with 32gb cards, I can only hope aaa
You lose the lastest firmware of the *istD but give it some higher number.
*ist-D: isde112w.exe you execute onto your harddisk at a chosen place.
You then have the actual BIN File = firmware: fwdc112b.bin
Now you have to play around
The DL firmware is called FWDC137B.BIN
You have to chose some higher number such as FWDC138.BIN
and so on until your *ist-D recognizes it.
This is what was explained (link I gave you) for the K30 with K50 firmware!
I recommended you study that link so you understand how to approach this.
