Originally posted by Argos Here are my measurements of Takumar lenses. Measurements taken with the lens flush to the measuring device. Picture of measuring device shows background radiation.
The only time that the film would be exposed to any radiation would be during exposure. X-ray film has very large silver halide crystals. Larger crystals mean more sensitive film. Back in the 1980's. 25% of the weight of a sheet of x-ray film was silver.
According to the Gurney-Mott theory of latent image formations, it takes three photons to strike a silver halide crystal in order for it to be reduced quickly by a film developer. A larger crystal has a greater chance of being hit. X-ray film has very low resolution as a result of the larger crystals.
Photographic films do have additives that can increase sensitivity. Gold chloride being the main one that I know of.
As measured with my GQ GMC-600+ Geiger Counter I get the following measurements.
At lens surface:
16,900 CPM (Counts Per Minute)
49.9 uSV/Hr.
5.35 mR/hour.
At the front of the lens I get 300 CPM.
At the film plane with the mirror down and the shutter closed I get around 600CPM.
125mm above the rear of the lens (The rear element is the radioactive one) radiation is already dropped to 10% of what it is at the surface of the lens.
My current background radiation level is fluctuating between 25 and 44 CPM.
The low level of radiation reaching the film may theoretically increase sensitivity a tiny bit.
Why was thorium used? It was used because when added to the formulation the result is exceptionally clear glass capable of razor sharp images if ground correctly. The yellowing was only discovered years later. I have seen glass from high altitude aerial recon cameras that has turned very yellow 30 years after it was manufactured. Quite pretty.
If you have any old hurricane lamps in your house, that nice cloudy glass they now have is the result of uranium oxide in the glass. Under ultraviolet light they glow quite a pretty green. Uranium glass started appearing in the 1830's. Even drinking glasses and tableware were made from it. never had a chance to measure how much radiation comes form the stuff.
