Originally posted by sany Hi mates
I've been away from the forum for a while. I earlier had Pentax K-r. I now own a bridge camera from Panasonic Lumix FZ1000. Since I was away for a while, lost track of whats going on in the Pentax world.
Could you all please suggest some (Pentax) compact body camera/small dslr that can support compact affordable prime lenses (normal (35mm) and one medium zoom (50mm or 80 mm range) with wide aperture). If possible, the body to have inbuilt stabilization and 4K video support. I don't mind a fixed lens but with wide-open aperture or a single focal length compact.
When I visit the Ricoh website it is very confusing, it mentions Q lens but not sure where the bodies are listed. Only a handful of models are there - maybe I am missing something.
Thanks in advance.
Ricoh, in brief : today there is a DSLR line, the GR line and the Theta 360⁰.
Q is an older system, lenses still available...
The DSLR isn’t the most compact as it still uses an optical viewfinder with prisma’s - which is a deliberate choice !
There is a bigger fullframe sensor K1 and slightly smaller APSc sensor K3 & K70 camera's.
The K70 is the more compact and cheaper one - entry model. One might still find a KP which is even more compact body but recently production stopped. KP is medium price range.
The pentax DSLR’S are primary photo camera's, and video is less advanced.
The K3 III has the better video features including 4k, it is also the newest model. Read here: Pentax K-3 Mark III Review - Movie Mode | PentaxForums.com Reviews .
Unfortunately it is also the more expensive one of the current models, together withe fullframe K1
Some of the newest pentax lenses tend to become bigger to improve image quality with more correction lenses and support fullframe (FA types)...but there are many smaller lenses , especially for the aps-c format K70 or K3II (DA types). The smallest are pancake type lenses - typically about 40mm or the DA aps-c lenses in the 20mm to 70 mm range,
I attach a picture of K70 with a DA 50mm f1.8 , a K3II with a DA 10-17 mm fisheye and a Lumix fz1000...so you can compare sizes.
Note that I tried to show contemporary smaller DA lenses on the DSLR's, in about the same size range as you indicated above, not the same zoom or focal length as the lumix - which i guess compares more to a larger DSLR 18-300mm zoom lens - the lens size would be more similar.
In the end it is a price , size versus video issue...
