Originally posted by Pedirob I had this lens with my KP and the autofocus did not work at all. It gave me an error message when I mounted it. Worked fine in manual focus mode.
I bought it used from B&H, so maybe I just got a bad one, not sure. I looked at the brochure on the Ricoh website and they actually didn't list the KP under compatible models, so I wondered if maybe it was not compatible with the KP. I returned it and bought the 18-55, which is an even more disappointing lens. Now I kind of wish I had tried another 18-135.
I'm curious if anyone has had success using the 18-135 on a KP.
This is surprising. I've used it many times on my KP when I need its versatility and need to reduce lens changing. In fact, its AF is one of the quickest and surest among the many zoom lenses I have. Even quite so on my older K-5 IIs, which usually lags behind the KP's AF when using screw-driven AF lenses. Otherwise, I often use one of my Limited prime lenses, or very often my DA 20-40mm Ltd for its compact carrying, or my Sigma 17-50mm f/2.8 when I need its larger aperture, and these I sometimes combine with the DA* 50-135mm f/2.8 when I need the aperture range with highest quality. Great for low light use, especially on the KP.
The DA 18-55mm kit lens does not compare even close to the DA 18-135mm DC WR lens, in build, imaging capability, or AF speed and accuracy. I used to have one.
It seems clear to me, you must have received a defective DA 18-135mm lens, since AF works fine with your other lenses. I bought mine new over 10 years ago, and it is still fine, delivering very good, high-quality images. Just needing to stop it down a little for best results.
---------- Post added 05-17-22 at 10:38 PM ----------
Originally posted by psoo I liked the lens a lot so I bought a used one to replace it. As others have mentioned, I believe there are a few lemons in the DA18-135 stable and you and I found them. Good luck in your quest to fix the problem
It is true that any lens made can have problems. But from what I've seen it is comparatively rare with this lens. I have actually seen more issues arise in postings here regarding the DA 16-85mm lens. Some have even had to return this lens more than once to get a good copy, while others get a good one right off. Then others have reported service issues, more then I've seen emerge from the DA 18-135mm lens.
