I think we all know my past as a top rated chef, so here are some beginner's cooking tips as well. Fresh seafood doesn't smell. When shopping, ask your fishmonger what time the catch came in. He'll probably lie, so don't hesitate to ask for proof. Be on the lookout for pale eyes and a fishy smell. If you detect these (in either the produce or shopkeeper) consider going elsewhere.
Frying is important, and there are several ways to check the temperature of your oil. The most obvious is with a thermometer, but you can also use the handle of a wooden spoon by dipping it in and seeing if the oil bubbles. Back in my sous chef days, the most common method was to flick hot oil at one of the newer kitchenhands and see how loudly they yelled. Thankfully, this practice has been abandoned, as it was not only cruel but also quite inaccurate.
Now to a recipe for silhouettes - underexposure. First, expose for the sky near the sun, not the subject. Spot metering helps (a tip about this to come) as well as locking off the exposure in manual mode so it doesn't change when you compose to include the subject again. Decreasing the aperture will mean you can get both your subject and the background in focus.
Then use the Flash Exposure Dial to go even darker. Go a couple of stops if necessary to get richer colours - be happy with the tones in the pictures you're chimping afterwards.
Artistically, the silhouette needs to have an interesting, unambigous shape to compensate for all the details being eliminated, since we have to rewire our photographer's mind to instead celebrate all the negative space. So, keep objects from overlapping unless you have a purpose uniting them. For example, a coffee cup could be turned so its handle is now visible, and a person can keep their arms and legs separate from their body so it's not one unflattering dark mass. In postprocessing, you can turn up Saturation and Clarity on the skies to taste, and because Pentaxes have such great dynamic range, destroy any details left in the subject by darkening those further.
A final cooking tip. While the kindest way to 'dispatch' a lobster is to place it in the freezer for half an hour before cooking, if you're pushed for time (or simply feeling angry) a metal skewer between the eyes will do the trick. I wouldn't recommend reversing the car over one, unless you're planning seafood patties.
The rest of the series here:
Clackers' Beginners Tips (Collected) - PentaxForums.com
