Originally posted by BelDel Unfortunately no A settings on any lenses.
And this camera stopped working on anything but lithium AA batteries a few years back! Used to work on any AA, but now only lithium! Go figure!
That is interesting, it is the same with my K200D. I purchased it recently as it had a very low shuttercount so I couldn't resist.
But when it arrived it came with ordinary AA Alkaline batteries and worked with those, resisted all my Eneloops.
As I have the external powersupply which works perfect it was clean that it must be a contact problem and when I checked it was clear:
The previous owner had cleaned all battery contacts but there were leftovers of a battery leak.
So I got 50% back and changed the contacts of the bottom battery door (one can use ONLY the contacts of another K200D, those of an *istD, K100D or Km will not work, have minimal different dimensions! but I had a few here). It is better but not perfect.
So I chose to buy a load of Energizer Lithium Ultimate which are perfect for the K200D, I can leave it in my car (well protected against humidity though) with some special SMC Pentax A-lenses and modified Pentax 360-I flash (also with the Energizer Lithiums Ultimate).
Quite a good solution, the K200D is a great body.
I highly can recommend some SMC-Pentax A lenses:
- A 70-210/4 ... very cheap to be found and almost as good as the
- A 35-105/3,5 (stack of primes)
and for the lower end I use the venerable DA16-45
and as a fast prime a heavy used FA50/1,7
