The basics
Focus Stacking: The Ultimate Guide (With Step-By-Step Instructions)
I used picolay for the photo postprocessing, quite easy.
A landscape ( or a larger scene) is easier to start , deep macro is more complex: the focus steps in the first are larger and easier to control manually, the latter macro might require millimeter precise focus steps hard to realise by hand, and because of small steps many more images...
While the first stack of large objects or a landscape can be easy, with a tripod, 3..5some pictures (fore, halfway and background focus points by manual focus) one will soon learn that there are quite some pitfalls and corresponding solutions...
- quite some lenses suffer from focus breathing - they zoom a bit while focussing - making picture matching difficult, can be solved by sw to some extent or by focus rails for macro work (you shift the camera to the new focus point without changing camera/lens focus), sometimes controlled remotely by stacking software on a focus rail with a step motor
- ideally all your pics should cover the full focus range, nicely spaced, accounting for the depth of field (light, lens, aperture, ...): there are apps to calculate how many pictures and focus points one needs and again some focus rails or sw can do this for you...
- moving objects (or backgrounds from even the slightest wind) can ruin the stack, favouring studio work. An insect on a flower in the slightest wind is a nightmare for stacking..
- manually changing focus can move your lens/tripod, resulting in non matching images , but can be solved by heavy, a sturdy tripod and remote control, best via apps for camera focus points setting & triggering. Sometimes referred as tethering , combined with downloading images on the fly for verification... also avoid shutter and mirror vibration (mirror up locking)
Fun but you need some dedication and time...
