I am trying to figure out how to remove the glass in a Pentax Rear Converter - A 2x-S without wrecking the lenses. It seems that there are two parts to the glass assembly, nested together and I can unscrew the outer piece from the inner piece but can’t do anything with the inner piece. I have not attempted to dismantle the entire thing as I figure there must be a simple way to do this and of course I expect that there are a lot of small parts that may go flying if I try to dismantle the whole thing. Ultimately I want o be able to put it back together to use as a converter. I am doing this to use it as an extension tube.
Any help would be appreciated!
Reason: Did not finish the post the first time
