Originally posted by krzys128 Have you already tried this card with Pentax K3 III ? Is it worth its price ? Technical data are impressive .
I wonder , only one slot accept UHS-II cards, what will happen if put this card into this slower slot ? Will it work ?
K.
Yes they're a bit quicker to clear the buffer based on my own use, particularly if you're doing RAW burst with a single card. Still, not a huge difference from the more economical Lexar 1667x, another card I recommend. I've been using the Sony Tough's for the past couple of weeks, but they are significantly more expensive and may not be worth the price difference to you.
EDIT: When I first tested the speed a couple weeks back I had inadvertently set both RAW and JPEG to Slot 1, no card in slot two which is how I'll prefer to shoot if speed is of the essence. I did not know I had enabled JPEGS too until this last weekend. I'd have to redo testing with no JPEG, which I never use anyway, to get a true speed difference with the slower V30 cards. Suffice to say there is enough benefit for me personally to stick with the Tough G's, but I wouldn't invest in a second pair. YMMV.
Note too that they're an ever-so-slightly thicker card and may be a little snugger in the slot and more careful to load on your K3III.
