Originally posted by OldChE It was my understanding that all of the film era Pentax flashes had low enough trigger voltages so that they are safe for Pentax DSLRs. Now, the TTL feature of the AF280T will not work on the K-1M2 DSLR, since the DSLR uses P-TTL (with a preflash) and the AF280T doesn't support that. However, you can use the AF280T in auto mode (using the sensor built into the flash unit) or use the flash on manual.
I haven't had it on my K-1 II yet, but have used it with other modern Pentax DSLR models, which cannot function using TTL, only P-TTL. But in this case, as stated here^ the unit's own "Auto mode" which I believe has two power settings, does a good job. And this is quite a compact flash but with very good features- tilt, swivel, and even a downward tilt for close work.
