04-23-2022, 10:15 PM   #1
Light Leaks with Pentax 6x7 MLU
Hey guys!
So I recently got a Pentax 6x7 MLU and I’ve been having some issues with what appears to be a slight light leak going diagonally across the edge of the frame in some images. It only happens on maybe 3 out of 10 frames per roll and sometimes less. Sometimes when I’m holding the camera in portrait and some not, but always in the same spot on the negative.
I figure it isn’t coming from the back door because there are no light leaks outside of the frame on the negatives too. I just replaced the light seals around the ttl prism, but they still appear sometimes. I’m hoping someone else has had this issue and can give me some advice! Thanks for the help! I’ll post some images with the issue
04-24-2022, 01:06 AM   #2
Is it the top right corner in the images? If so, I can see it in the first one, but not the second.
04-25-2022, 06:20 PM   #3
Look above the chimney on the right, most visible below the power line.
Would need to see more and the full uncropped frames, ideally as proper contact sheet(s). We don't know the time duration that a frame sits between spools or light conditions.
6x7, camera, frame, images, issue, leaks, leaks with pentax, light, light leaks, pentax, pentax 6x7, pentax help, photography, troubleshooting
Pentax 6x7 MLU light leaks in frame FarBox4697 Troubleshooting and Beginner Help 0 04-14-2022 09:09 PM
Pentax 6x7 MLU counter not advancing Snakehn Troubleshooting and Beginner Help 2 08-23-2021 05:15 AM
Pentax 6x7 MLU parts needed Bruxxcam Pentax Medium Format 6 12-13-2020 01:33 PM
Pentax 6x7 MLU shutter not opening olivexrush Troubleshooting and Beginner Help 2 12-04-2020 02:05 AM
Pentax 6x7 light leaks Pedrosa Troubleshooting and Beginner Help 9 08-03-2014 03:03 PM
All times are GMT -7. The time now is 10:48 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
