I have the XPro-P also. I have never had any errors with it strictly firing with no delay, and that is basically the way I use it. It may be that since the transmitter is working strictly in its own Godox function commands that it does not recognize the delay command you are testing with. If I wanted to do the delay setting on the camera, I would use it in association with pressing the shutter button on the camera and let it go from there if I had the XPro-P on it. I have not tried it yet, but that is the way that I would probably approach it. These are just possibilities that I am expressing. The XPro-P may not be recognizing the infrared signaling activation as opposed to the regular shutter button activation on the camera itself, which also may be just a possibility.
