Originally posted by seventhdr Ah! That sounds like it might be the problem. There's always a bit of a delay as the commands travel from your camera, to the flash transmitter, to the flash receiver to the flash that can cause some delay. I used to shoot with a Canon 5D Mark II and though the flash sync speed of the camera was listed at 160th of a second, I think, I had to lower the shutter speed to 1/125 to reliably get wireless triggered flashes to fire.
Going from 1/180 to 1/50 to get reliable sync seems quite a big delay. Can you try any alternative triggers?
Also can you use a sync cable to the flash? This would check whether there is anything in the camera contributing to your sync problems.
Regards
Chris
I don't remember the K-x having a X-sync port, only the hot shoe, and I used exclusively the hot shoe with wireless synchroniser, with sb25, and well, the built-in.
I remember that there is this little nub on the hot shoe, can it be a problem?
