05-18-2022, 01:49 PM   #61
que es tu's Avatar
QuoteOriginally posted by BigDave Quote
Another thing to keep in mind, with memorizing f stops. Just remember two of them, f4 and f 5.6. Then you double every other one (or half going down) so f4, f5.6, f8 (double 4), f11.2 (the actual f stop, double 5.6), f16, f22.4 (rounded to 22), f32 and f45 (actually 44.8, rounded to 45). Going down from f4 gives f2.8 (half of 5.6), f2, f1.4 and then f1 (a very rare bird!).
I remember seeing a Canon f .95 in a photo history book. Is this even possible, or just a gimmick??
05-18-2022, 02:39 PM   #62
UncleVanya's Avatar
QuoteOriginally posted by que es tu Quote
Absolutely. Even F0.7 is out there in the wild. F0.95 is not nearly as hard.
05-18-2022, 02:53 PM   #63
Just1MoreDave's Avatar
I have one (sort of). It was removed from a TV camera. It doesn't have any focusing and I think its flange distance is not adaptable to K-mount, so I've never used it.
05-18-2022, 07:51 PM   #64
swanlefitte's Avatar
I would think the camera mount would limit it at some point. A Pentax mount has a 42mm opening. A 300mm lens would need an entrance pupil of 315mm diameter. I can't imagine the opening at the back big enough.
05-18-2022, 08:26 PM   #65
UncleVanya's Avatar
QuoteOriginally posted by swanlefitte Quote
True to a point but remember that the entrance pupil size is not directly linked to the physical aperture only. The apparent size can exceed the actual. And the exit size isn’t part of the formula.
05-19-2022, 03:12 AM   #66
As I recall this lens was made for the rangefinder camera.
05-19-2022, 03:51 AM   #67
In a circle, the surface is a comma, it's not as simple as a quadrilateral - Lxl. That's why the diaphragm story seems complicated and, in most cases, useless. It is important to know the basic values ​​that double or halve the exposure - 1 stop. These are 1 and 1.4. If you double them, you get the diaphragm string (stops). Ex: 2, 2.8, 4, 5.6, 8, 11, 16, 22, etc. All others are 1: 2 or 1: 3 stop fractions.
05-19-2022, 04:58 AM   #68
UncleVanya's Avatar
QuoteOriginally posted by Peanut Quote
Correct. There are also tv lens versions converted to Leica M mount and perhaps native m Mount versions. Several mirrorless cameras models has f/0.95 lenses made for them as well.
answer, aperture, bit, camera, chart, click, f4, f8, half, increase, iso, light, noise, owners, pentax help, photography, sensor, troubleshooting, wheel
645Z + FA 645 55mm: Sharpest f-stop at f8 or stop down? Hyperfocal issues.... steve645z Pentax Medium Format 31 01-09-2017 08:08 AM
People Stop stop... no more pictures! ppppsssstttt Pentax K-3 Photo Contest 2 06-03-2014 04:19 PM
Don't say Pentax "Q" in French ... "Q" = "cul" = "A--" Jean Poitiers Pentax Q 52 11-10-2013 06:25 AM
Misc When i say stop it means stop ! deadprez Post Your Photos! 3 08-02-2011 07:38 AM
All times are GMT -7. The time now is 01:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
