05-13-2022, 10:23 AM   #1
Sigma 35mm Art and dock adjustments
Morning from Colorado!
I have a Sigma 35mm f1.4 Art lens and the dock. I'm using the lens on the K-3iii and K-1ii. I discovered at f1.4, it front focuses slightly and I tried to use the Dock to make adjustments. While I was able to set it correctly at short range, when trying it at infinity, the lens produced images similar to me without glasses Resetting to default settings returned it to pretty good (not great), but still front focused at close range.
I now have a couple of questions:
1) Has anyone been able to absolutely fine tune their lens using the dock or am I being too impatient with my settings?
2) Does the dock really improve your focus with this lens?
3) If you've had good success making adjustments, what's your secret?
AnotherVoice
05-13-2022, 10:36 AM   #2
I use the dock with both the Art 35 and 18-35. In use the Art seems absolutely spot-on now with the K3III, but I can't say I've tested it at infinity. I might have but suspect not because of what I use it for, full-body portraits and modeling. The 18-35 needs adjustment across the range of the zoom, and on the short end, up to perhaps 20 feet away, it's perfect after the dock visit. On the longer end I remember it not being as crisp as I like but I'd actually have to look again.
So short answer is the dock worked for me, but to completely answer your question I'll have to put them both on camera and carefully look at a full range.
05-13-2022, 05:41 PM   #3
Paul the Sunman's Avatar
QuoteOriginally posted by AnotherVoice Quote
Mine is pretty good, though occasionally inconsistent. I ended up making no adjustments in the dock. I use it on the K1, but haven't tried it on the K3iii yet.
05-14-2022, 02:30 AM   #4
K(s)evin's Avatar
Can you use the in-body focus adjustment for close-up, or does that throw all of the dock adjustments off?
05-14-2022, 03:15 AM   #5
Returned the first A35art due to focus issues, returned the second one with dock as well for the same reason. The dock is a decent idea, you feel like you are in control. It reality it means that Sigma imposes finetuning on the user and the process is a nightmare. If you carefully calibrate all settings, you can spend hours. I am done with Sigma and the dock. I would wait for the Pentax * release in this area.
05-14-2022, 04:21 AM   #6
I found that the lens focused fine on the first short and then missed everywhere unless I turned off the camera and removed the lens. Hours spent with the dock didnít solve anything. I returned both.
35mm, adjustments, art, art and dock, camera, dock, f1.4, lens, pentax help, photography, range, settings, sigma 35mm art, troubleshooting
For Sale - Sold: Sigma 35mm Art f/1.4 for Pentax, pouch, USB dock cdd29 Sold Items 7 06-23-2021 05:33 PM
For Sale - Sold: Sigma 18-35mm F1.8 DC HSM (Art) and USB Dock - PRICE REDUCED mr.b.snowden Sold Items 14 01-12-2018 01:21 PM
For Sale - Sold: Like new Sigma 35mm Art FOR Your Sigma 18-35mm Art lens! Fenwoodian Sold Items 7 10-09-2016 05:47 PM
Sigma 18-35mm f/1.8 "Art" and the USB Dock panoguy Pentax SLR Lens Discussion 3 10-07-2014 07:29 PM
All times are GMT -7. The time now is 05:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
