Originally posted by mlag Before sending repairs , I would check with no or another lens, with (other) freshly charged batteries and with only one & other sd card ( or re-format), just to exclude external causes...one never knows.
And without battery grip, if you have one...
Ricoh states that camera settings are retained if you remove/replace battery within 48 hours after a battery was present for 24 hours. This info can be used in two ways:
- You could attempt to erase all settings by leaving it without power for at least 48 hours (with decent margin, because if manufacturer predicts 48h it is probably more like 3 days...).
- if your camera was stored longtime with low/empty battery, you might try to keep charged battery in it for some hours .. up to 24 h, to beef up the internal memory retaining battery before testing camera.
Above can help for a sw glitch, for instance caused by too low battery, an accesoiry like lens draining too much current, a malfunction on memory card, ....but not for a hw failure.
Thank you for the suggestions. I feel like I tried different things, but will give it a go again.
I'll also try to leave it without battery, but I'm doubtful it will help. I still have my 2 first K-3 II's. They've been shelved a couple of years and I used one last night for some 800 shots. I didn't notice anything odd, which might be caused my low juice on internal battery.
The other however, suffered from same or very similar looking issues and still won't work. I've now left it with a fully charged and original battery to see if that will do anything, but I'm skeptical.
Originally posted by Mikesul Serial is not within the range. It's 60207833.
The first ones I bought, were bought about 2-4 week apart and are both within the serial range. One suffered after 224k exposures and I see now, it does not turn off. I never noticed this before with any camera, except for a camera freezing. IIRC, K-30 suffered more from that.
The other one is currently at 216k, working and turns off fine, but was previously repaired for same or very similar issue (black screen). I don't remember what shutter count was at that time and it was after 2 years of use.
