Originally posted by Shanshay
OMG how stupid am I - it's a canon compatible one. Is there any way I can use it in manual mode?
Possibly … you'll need to be in Manual mode, with the shutter speed set to 1/180 or slower, (or possibly X Mode for a non-Pentax compatible flash) then set the aperture according to the distance from the subject, the Guide Number of the device and the ISO selected on the camera … (old-school manual flash photography!)
If the flash fires and you get "some kind of exposure" you can then "jiggle it a bit", ie. adjust the aperture or ISO appropriately, for a correct exposure.
Not ideal for an insect or similar which may spook at the first flash, but for more inanimate objects should be perfectly OK.
If you establish that it can be made to work, you'll be able to draw up a reference chart for yourself to know what settings to use in the future.
The flash will probably only fire at full output (if at all) so you may need to fit an ND filter to the lens to tone things down a bit if working very close.
Unfortunately, if the flash doesn't fire at all, there's probably nothing you can do about it.
Good luck
