Originally posted by ramseybuckeye
Flickr reports Multi Auto white balance as Auto on all of my photos, I use Lightroom. I may have to try uploading a photo from DCU sometime. I’m not at home now to check, but are there different parameters for jpg exports in DCU?
Short answer:
If I process an image only with DxO, it gets reported by Flickr as AUTO (File EXIF does says Multi Auto)
If I process with DCU, it gets reported by Flickr as MANUAL (EXIF file does say Multi Auto)
I use exiftool command line and did a comparison of the 2 EXIFS
I do not see any obvious place where the change is made.
---------- Post added 05-29-22 at 09:28 ----------
Originally posted by Larrymc
The lens info can be easily "fixed" by using EXIFToolGui and it will show in Flickr.
Yes, I already do that in the command line due to Pentax putting the lens info in the Maker Notes.
exiftool "-lensmodel<lenstype" works great except for Sigma, that one has to be exiftool "-lensmodel<lensID"
This is a case of the correct White Balance in the EXIF but DCU adding info somewhere that negates it per Flickr.
