Originally posted by Billy Bokeh Do you think that the need for the lithium batteries is because the 3v battery is aging?
Yes. I have a K200D which I got about a year ago, it had a super low shuttercount. But the 3V C-MOS was bad.
I didn't want to take the motherboard out, imo more risk than positive sides.
But I lifted the motherboard and clipped the 3V Lithium off.
Since then no problem.
If one leaves the K200D without batteries for a night and it then askes for date/time, then you know the C-MOS is over and done with.
And it will drain, just that Lithiums live much longer.
I am not sure if this is the only culprit because my K200D wouldn't accept new Eneloops at all!
Only the best lithiums.
Maybe there is another culprit not yet detected.
Originally posted by Billy Bokeh Allthough those with the ability to solder, the hardwired 3v shouldn’t be much of a challenge- just inconvenient and time consuming and requiring some skills.
It isn't that easy. Best to clip it off and leave some of the feet on the board and solder the new 3V Lithium to those feet.
Soldering directly on the motherboard means you need quite some heat which very quickly damages the strip-conductor on the board.
Happened to me once with a K30
Originally posted by Billy Bokeh This particular K200D used has over 217,000 shutter counts now. I’m overall pretty impressed with the reliability of my K200Ds and K5IIs. I’ll give credit to Pentax for making a rugged camera.
Indeed, I will quote this in another thread!
My first K5 has now over 100.000 and works fine (with Katzeye)
