Originally posted by pentaxus
Press the depth of field preview button (round button above the self timer) and the lens should close down.
Depends if it is the Pentax KM film-camera or the digital K-m (K-2000 in USA)
His is the K-m/K-2000 DSLR as you can tell from his profile (at least no KM film version is mentioned)
But the way he wrote his first message hints towards the early Pentax KM film version.
@Arnk_i: Always good to be precise, particular with KM vs. K-m (or KX vs. K-x). But also about which lens you use.
This usually helps a good deal, doesn't lead to unnecessary confusion.
Have fun with the K-m, which is the last Pentax with a 10MP CCD sensor. Also a very simple AF with just 5 AFsensors, something Pentax did only with the K-m, it is a simple but very nice camera and worth to be used with good lenses.
Not to use high ISO, one could say everything that is recommended for the K200D goes for the K-m, same sensor and chip, they
took the chip changes applied from the K10D towards the K200D into the K-m. So it makes very good natural photos and has a good
JPEG engine. And with the K-x it is the smallest DSLR Pentax made with SR (shake reduction). The K-x has the new 12.4 MP CMOS sensor, similar to the one in the K-r, both of those very nice for vintage lenses, because their sensor doesn't show up limitations that strongly.
I use the K200D (and at times the K10D) again and again, the K200D is always in my car.
Get yourself either a good set of Eneloop Pro AA's and a really good charger.
Best value-money is the Technoline BC700:
https://www.tme.com/us/en-us/details/bc-700/chargers/technoline/+
Or use just Energizer Lithium Ultimate AA's.
They last very long and if not used, can be stored without danger for 20 years, they don't leak!
