Will it run through a cycle other than the mirror coming down?
So if you press the shutter button, will the shutter operate and the film try to wind (even if it's empty)?
Which red light did you say came on?
Do you get the meter indicating inside the viewfinder? (I think the A3 tells you a little in there...)
It sounds like a) the shutter/mirror relationship is no longer as it should be and it needs a real repair... or b) it died in the middle of a cycle when the last set of batteries went, and it just needs something to trip it into completing that last cycle to start it working again...
I don't recall if the A3 stops working properly when empty (some cameras do...). It will probably say in the manual, but you may need to fool it into thinking it has film in it...
-Eric
